Hello everyone, I’m trying to set up a setup for an ideal worstation for jobs (not games) with SketchUp and Enscape. The ideal is that this computer has performance and not very high cost. I expect colleagues to make variations for pockets less prepared like me. To start I’m suggesting a station that I consider ideal, however expensive. Please help with ideas.
Computer with 4th Generation Intel Core i7 processor (3.4GHz, Quad Core with HT and Turbo Boost), 16GB DDR3 memory, 2TB Hard Drive (SATA 3 - 7,200rpm) + 220GB (SATA 3) SSD, NVIDIA Quadro M2000 (4GB) video card, 8 (7.1) channel audio, 10/100/1000 Gigabit Ethernet network and wi-fi, USB 2.0 and 3.0,
card reader, Micro ATX enclosure and 520W real power supply - two 21 "ultra hd monitors
Sftwares: Win10, Sketchup 2018, Enscape last version, Photoshop (gimp or another), Shader Map, Office
520W is far too low, go for one in the 800 range
If your using Revit then the Quadro might be worth it but a GeForce 1060/70/80 would give you more bang for buck as neither SketchUp or Enscape make use of the features a Quadro adds above a GeForce.
Get an SSD and a HD, have the SSD as your boot drive with Windows/Apps etc and the HD for files, a 250GB SSD would do it
Intel i7 no less than a 7700
You want DDR4 not DDR3 memory, 16GB would be the minimum but more is always better.
We use revit, and used to buy the expensive quadro cards but have shifted to the gtx series, and have not looked back.
Jorgensen
is anyone seeing any performance difference in sketchup on i7 vs xeon
anecdotally, seems the xeon boxes seem a bit faster editing despite their much poorer graphics cards, (quaro2000s vs gtx1080)
its not enscape performance, its in sketchup?
Firstly, thank you to those who responded to the post. I see that the ideal workstation for computer graphics is forming. The working software is basically autocad, sketchup / enscape, v-ray, photoshop, gimp, office, shadermap, streetview 360 °, etc. In addition to browser,
onedrive and often working with several of these open features. However, anyone who uses Rhino, Lumion or others can benefit from this setup.
@wagnoldo Enscape is rendering on the GPU only. CPU and RAM are used for your basic software solution and the loading of your project into the Enscape engine.
I definitely recommend to go for a GTX 1070 (Non VR)/1080/1080 Ti or wait for the new RTX series.
