IM+LC Calculation for animation with Moving camera
Hey
A Little question.
i am working on a scene of 3000 F with moving objects and moving camera - after reading here and there i found out that the best way for me is using this method http://www.spot3d.com/vray/help/200R1/tutorials_anim2.htm
as written in the tutorial .
my question is : is there any way to speed up the calculation - it takes about 3-4 min for each frame to be calculated - in the overall it gets to almost one weak of gi calculation .
is it possible to calculate each 3rd or 5th frame to speed up the calculation ?
i am working on 1280*720 res.
any settings that i can tweak ?
thanks
Dan
Hello Rufos
The answer is no - rendering scenes with moving objects requires GI calculation on every frame, and 3-4 minutes per is a very acceptable render-time.
You can speed up calculations by optimizing your scene for faster rendering , sometimes it is even possible to divide your scene on static and dynamic part , like to following example:
Chaos: Industry-leading design and visualization software … and you can render static objects with fly-through approach, Chaos: Industry-leading design and visualization software and then render dynamic objects with moving-objects approach.
hey
is it possible to calculate the gi in that method using multiply machines ?
Dan
Yes it is possible.
You can split your animations to sub-animations, and send every piece to separate machine.
You can also use Backburner and send every frame to a different machine.
It is also possible to use Vray Distributed rendering and all machines will be used in the calculation of every frame.
wow Cool
That is really nice .
just one more question - if i decide to use the backburner method - is the LC will be calculated as well and backed in to the IR Map?
Yes - when Irradiance Map is used as primary engine it will also store secondary bounce information - Light Cache or Brutte Force.
Edit:Solved- cast/drop shadows off on the transparent object fixed it
Hey
I just did some quick render test after i finished the calculation.
The issue is that i have transparent cover on the top part of the image-( the screen) and in that part i receive noise and flickering - the rest of the frame is great .
any tips on how to solve this ?
Dan
