Imported materials not syncing in Asset Editor until restart
Hi Chaos Team,
I am experiencing a critical UI sync issue after updating to the latest versions of SketchUp and V-Ray.
Problem Description: When importing external components or models into an active SketchUp project, the geometry imports properly, but none of the corresponding materials appear in the V-Ray Asset Editor material list.
Current Behavior:
  1. The imported materials appear correctly inside SketchUp’s native Materials tray.
  2. Sampling the texture on the model using SketchUp’s native eyedropper tool confirms the material exists in the model, but it still does not populate or trigger a sync inside the V-Ray Asset Editor.
  3. Starting an Interactive Render does not force the Asset Editor list to update.
  4. If I save the file, close SketchUp, and reopen the project, all imported materials immediately appear in the Asset Editor.
Key Context: With the previous update, everything worked flawlessly and materials were synchronized instantly upon import. Having to save, close, and restart SketchUp every single time a model or component is imported creates a massive bottleneck and disrupts the entire workflow.
Environment Details:
  • OS: Windows 11 (64-bit)
  • SketchUp Version: 26.2.243
  • V-Ray Version: 7.40.02
Is this a known regression in build 7.40.02? Is there a hotfix, a specific NeUI refresh command, or a viable workaround to force-sync the materials without constantly restarting SketchUp?
Thank you for your support,
Mattia
Hello @Mattia_Maruccia ,
Thank you for reporting this.
Unfortunately, this is a known issue that our team is currently tracking. As a workaround you can release V-Ray License (Extensions > V-Ray > Help > License > Release V-Ray License) and reopen Asset Editor — the imported geometry materials should then dislay properly.
You can find additional details in this forum thread. We will let you know as soon as we have news on a fix.
Kind regards,
Iva
