jop
November 25, 2019, 8:32pm
1
I have some brightness inconsistency from frame to frame on renderfarm.
Not a texture gamma issue.
Comparing frame/node, it appears that intel xeon vs amd threadripper produce different results.
Using max 2019 with Corona 5.
Have to take some time to setup a test scene.
We are aware that there can be some differences rendering on different CPU architectures. It looks like something similar was reported here: https://forum.corona-renderer.com/ Water flickering with network rendering. #msg155463
It would still be helpful if you could send over a testing scene and some screenshots if you are able to.
Thanks,
Rowan
(Internal ID=323484663)
jop
November 26, 2019, 11:01am
3
Upload done : 1574766047_Test-CPU-Architecture.zip
Here are 2 screenshots too.
Intel seems to produce more artefacts.
maru
November 26, 2019, 2:01pm
4
What exactly do you mean by a render farm? Your own local render farm, or an external render farm service?
None at the moment. We are still investigating this issue.
We’ll do our best to keep you updated when we have some more information.
Rowan
jop
January 29, 2020, 9:00am
8
Hi Rowan,
it’s been a while
Do you have some good news ?
So the good news is that we now know what is causing the problem.
It is with the dev team and they are looking into a fix for it, but as usual I can’t give you a timescale.
Thanks,
Rowan
jop
June 21, 2020, 10:46am
11
Hi Rowan,
Do you know if this issue will be adressed in v6 ?
Hi jop,
I am not sure, I will poke our dev team again and let you know when I have some info.
Cheers,
Rowan
This is fixed in v6 RC3, please test it out and let me know if there are any issues.
Cheers,
Rowan
jop
August 19, 2020, 4:35pm
15
Great news !
I check asap, thanks !
otuama
December 13, 2020, 8:20pm
16
Hi. We’re having the same issue on a job.
We’re using a render manager and it seems like certain systems are rendering differently. Different colouring.
A few systems may have different versions of corona 6 installed as it may have been reinstalled on them for whatever reason
To be safe I better install all systems with the most recent version but is there a way to see which build of corona I’m running?
I can’t seem too see this info anywhere.
It will be best to install the latest version of Corona (v6 HF1) on all systems as this issue was fixed very close the release of v6.
To find the version you can launch 3ds Max → Render Setup (F10) and go to the system tab.
btw, if you continue to have issues with this please start a new thread as it may not be the same problem.
Cheers,
Rowan
