I am doing some testrenders with some pretty heavy scenes.
With a “pure” render without any extra elements, not deep or anything, the rendertime is approx. 3 minutes.
When I add render elements, this suddenly becomes 20 mins instead. While I understand that the rendertimes will be somewhat higher, I just don`t understand why it is THIS high.
I added all the render elements needed to rebuild the images in Nuke (diffuse, reflection, etc). In addition there is Deep, Velocity, AO (radius:1000, samples:128 ), five light selection elements in normal mode, and a few cases of Sampler info. The sampler info contains things like UVW coordinates (several types), points and normal vector.
Can those things really add that much to the rendertime? are there any render elements I should be particulary aware of?
Could you try with all the render elements except AO ? My guess is that it causes that massive increase in the render time..
If it turns out to be the problem - you said it is with 128 samples - you mean 128 subdivs ? That is quite a lot (16384 rays for every shading point) - are you getting bad results with lower value ?
It`s the AO that is the problem as you said
The scene is 10x bigger than its real world scale, which is why the radius is so high. I just didn`t think it would be that taxing. But anyway, thanks for the help
Its alright guys. I just wasn`t aware that AO used that much horespower. Previously I only used it a tiny bit to get more interesting shadows, but this time I needed more for post. I will spend some time to figure out how much AO I really need
I am confused now. I though subdivs are handled by VRay automatically now? The VRayDirt subdivs don’t? I always assumed is was a bug that you could still enter subdivs there and it’s not grayed out.
