perchè utilizzando enscape trial, al primo lancio non carica e rimane bloccato al 5%?
@salvatore_1 , this issue can occur due to multiple different reasons - To get behind the cause of this problem of yours, please kindly send us a Feedback Report with your log files:
https://enscape3d.com/community/blog/knowledgebase/using-the-feedback-button/
@salvatore_1 , este problema puede ocurrir debido a múltiples razones diferentes: para conocer la causa de este problema suyo, envíenos un informe de comentarios:
Thanks a lot in advance!
valutazione inviata…non sarebbe possibile avere enscape trial versione precedente… puo’ essere la versione 3.2 causa dei miei problemi?
My colleague also sent you a reply but, unfortunately, with only 2GB VRAM available your GPU is not supported anymore with 3.2. Please follow the steps she also provided in case you wish to downgrade Enscape to continue using it. Eventually, you may of course also want to upgrade your machine accordingly to make use of all the new features we provide currently and in the future.
