initializePlugin function failed (vrayformaya)
My computer runs well when I call up the V-ray plug-in.
However, an error occurs when the plug-in manager unchecks vrayformaya.so and then checks it again.
In the script editor, “/usr/autodesk/maya2020/scripts/others/plungin.mel : line 317 initializeplugin function failed (vrayformaya)”
print as
I reinstalled the V-ray, but it won’t be fixed.
Tell me how to fix it.
Thank you.
This is a known issue, however, there isn’t a solution for it at this point. We do not recommend force unloading the V-Ray plugin by hand; rather use the Auto-load option to control whether or not to load the plugin on Maya start.
Same here. I can select Vray in the Render settings, but no shelf and only auto-load can be checked.
Windows 10, Maya 2022.2, vray_adv_52000_maya2022_x64
Is the vrayformaya plugin loaded? Is the loaded checkbox checked (next to auto-load)?
If V-Ray is loaded, you can force re-create the shelf from the render settings > settings > V-Ray UI > create/replace V-Ray shelf.
