Installing the recommended Windows Drivers for V-Ray GPU on Windows
The recommended Nvidia drivers for V-Ray GPU are tested and verified by our QA. You will find the recommended drivers for Geforce and Quadro cards on our V-Ray GPU product page. Currently the recommended driver for Geforce cards is 572.16 Studio driver and for Quadro cards is R570 U1 (572.16) Please keep in mind a stable driver is big part of a reliable GPU rendering experience, please don’t update your drivers whenever Nvidia releases a new build, you need to wait for us to test/verify before updating. If you use an old or new drivers you will find a warning message in V-Ray’s log.
It is normal that we recommend a certain driver for up to 3 months, this happens if there are issues with newer released drivers. We communicate closely with Nvidia when we recommend a certain driver, and if we found issues/instability. If you need to update your current driver for compatibility with other applications please send me a message here or an Email to muhammed.hamed@chaos.com, we will test and verify a new driver for your case.
Installing the recommended drivers for V-Ray GPU
Nvidia Control Panel Settings,
Keep in mind that doing a Clean Install of drivers resets all settings to their defaults, so you will need to change these settings every time you install a driver. The following settings are key in getting the expected performance out of V-Ray GPU. Additionally when you launch the Nvidia Control Panel from Start menu and click on the home button you will verify the version of drivers you have installed
  • Go to Manage 3D Settings, Scroll down to Power Management Mode and change it to Prefer Maximum Performance(this slightly increases the power draw of the GPUs in idle state by a slight margin, this is very important to avoid performance issues on GPU rendering with Vantage and V-Ray GPU). Click on Apply Changes
  • If you have multiple GPUs, Change OpenGL rendering GPU to the card you have your monitors attached to(this card will be used for viewport performance across all DCC application) and Click on Apply Changes
Other Windows Settings we recommend for GPU rendering,
We recommend enabling Hardware-accelerated GPU scheduling option in Windows 10 and 11(enabled by default in Windows 11) This will free up VRAM accessible to V-Ray GPU on your GPU(s)
This option is available Under System, Display, Graphics, Default Graphics Settings
This option requires a system restart to take effect
If you have questions please let us know
Best,
Muhammed
Image Upload(Ignore)
Recommended driver updated to 561.09 Studio driver for Geforce cards, and R550 U9(553.09)
Recommended driver updated to 566.14 Studio driver and for Quadro cards is R550 U12(553.50)
Recommended driver updated to 572.16 Studio driver and for Quadro cards is R570 U1 (572.16)
Recommended driver updated to 576.80 Studio driver for Geforce and Quadro cards. If you see a warning in the log please ingore. We will fix this ASAP
Recommended driver is updated to 610.62 Studio driver. If you see a warning in the log please ignore, the log will be updated soon.
