Instancing of sun and sky
possibility to instance corona sun and sky.
It’s possible to instance of course, but the light does not correspond to the original.
Also not working when instancing a parent-null instead of the sun/sky object itself
Making it editable again crashes c4d
thank you for your consideration
Can you explain what the use case would be here, over just adding a second non-instanced sun and sky?
