Hello Devs,
i found out that the interactive likes to crash a lot when displacement is turned on ;(
Especially when it has to load many instances or renderinstances.
Wouldn´t it be possible to give us a possibility to switch displacement off globaly !?
Sometimes its not needed to have it on, for example in my case with big archviz scenes if you have to set sunlight.
To go through every single material is quite annoying… Furthermore it would render faster than !
just a tip…
THX & Cheers,
sV
There’s always been an easy way to enable/disable or set any & every kind of property for multiple materials (so even globally).
Just select materials and set properties in Material Manager.
Also, using Layers helps with better organization and makes workflow faster - ie. selection of all materials with displacement can be shortened to single click.
As burnin mentioned, select all the materials and disable the displacement in the attributes window. If you need to turn them back on, just repeat the process. This will obviously enable displacement for all materials, but will only affect those that are using the texture slot.
Also, can you please send us the crash report and scene if possible? Any crash we take seriously so It would be nice to know what is going on here and hopefully prevent it from happening any further. Feel free to use our private uploader that can be found in my signature below or you can reach us at support@corona-renderer.com. Thanks in advance.
