Interactive rendering animation update
Hey guys,
I’m working on an animation project and moving the timeline marker, updated the IR to the actual frame.
I’ve added a new light and it suddenly stopped working…now I have to manually stop and start the IR the update the actual frame view. Actually if I advance frames, it does recalculate, but doesn’t update anything.
I’d love to have it back working, any workaround? :smiley:
Thanks!
Hi, Are you using the latest daily build and can you share the scene file?
Funny thing is, it worked and then stopped working :smiley: I’ve downloaded the most recent daily build, installed and back to working.
So all good, thanks for the help!
Can I ask are you using the preview as the finished animation?
Nah, not really. Preview is set to 10-15 passes, final animation around 30-40 pass limit.
Working on a workstation with 2xE5-2696 v3 and 64Gb RAM, that setting gives pretty good update times in preview.
ok thank you
