Sorry, I think I broke something (~20times)
AutoBackup01.max (3.34 MB)
Does it only happen when you are rotating the sun? Or generally?
Which Corona version is this?
What is your CPU?
I just checked and I am not experiencing this problem here.
Please see this:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006
“1. Reporting a crash”
this happens only when I rotate the compass.
max 2015 v. 1.00.02
Xeon e5-2620
tnx.
3dsmax_minidump.dmp (8 MB)
Does it also happen if you go to daylight settings, switch position to manual and then change sun’s position? (sun object, not compass)
yes it occurs, but not immediately compared with the rotation
The crash seems to happen in vray. Is there Vray HDRI loader used in the scene?
yes, sorry, this vray HDRI problem.
In the future you have planned support Skylight? when it will be?
Thank your team for taking care.
Do you mean the Corona Sky map?
https://coronarenderer.freshdesk.com/support/solutions/articles/5000516719
No, I mean the default 3ds Max Skylight )
I just wanted to rotate the sun with the *.hdr maps. For what would be the shadows were always united. I’ll find another way.
But it is not very important. Without me, you have enough problems, I think.
Thank you.
Corona sun is always connected with sky, so when you rotate sun, the sky updates accordingly.
See this if you want to align sun with hdr:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000516732
And there was also this:
Thank you very much, it is very powerful links =)
