Im using corona 12.1 and max 25
WHen the interactive is running and you resize it, the rendering is supose to fit the new size, sometimes this is working other times its not.
Previously the render elements could be changed with the mouse wheel just if the pointer was on top, now you have to click on the menu for it to work, Please change this behavior !
We had one or two reports like this, but we were never able to reproduce this on our end. Are you aware of some specific steps to trigger it? Or is it happening randomly?
Its happening randomly, but i have found it a couple times already.
thanks a lot for the video, that helps a lot. Unfortunately I still cannot reproduce it. I can see you have some high dpi wide monitor, is that right? Could you pls post here your monitor setup you have (how many, which one is primary, and their dpi)? That would help be really helpful - as it might be problematic only in your specific setup.
Best Regards
Jakub
I will note that this very rarely happens to me. Mostly when I get back to VFB after some time of being idle, start IR and resize the VFB.
No reproduction so far, even after it happens…
Hi Jakub
My display resolution is 3840*1080, just one display on this one pc (this one is sitting at the office) Im remoting to it trough parsec.
Windows scaling is at 100%
I tried connecting through Parsec, but still couldn’t reproduce it. It seems to be very random so I am not sure if we will manage to investigate.
