Interface very sluggish when running Vray RT
Since I switched to max 2016 and updated VRay to 3.20.02 I noticed that while previewing the scene with VRay-RT, the whole interface because extremely slow : dialogs take seconds to update, same for materials when I change any value.
Please note that I run Vray-RT on the renderfarm and disable “Auto-start local slave”.
Anyone experienced similar issues ?
Just decrease the values of Samples Per Pixel (to something between 1 and 4 for example) and Bundle Size (to something between 32 and 128 for example). Test to see what works for you.
You can check more about that here Chaos Docs, section “Balancing the GPU Load”.
