Hey ! Louis !
maybe think about the space when the night is coming !!! nothing to lights it ! … then put some nice luminaires in your daylight scene ! it will look less sureal…
also you could change the lens size… maybe you use something like 50 mm..then you should have a lot of space in your back to put your camera…but the place looks like a student room. And student flat and space don’t go together !
so … use soemthing like 28-30mm lens…maybe it will also look like less “childish” “toy” room. and then less cartoony..then more realistic !
also you could add a bit of an environement in the windows…add also the detail of the plinth on the wall and maybe less icons on the screen (i was really focusing too much on it ..it is abit “maniac” desktop arrangement ! )
but but…your fabric look f*** realistic as well for the wood..even if it is the same everywhere !
and nice light ! ah yes put maybe some direct light in the room…some shadow and contrast, quoi !
but really well on the perfect track !!!
I’ll give away the texture … actually it may be a texture from a wood floor company. I’ll see if I can find where I got it from … It won’t be available till tomorrow when I’ll be at job … cause for now … I don’t have access to the file …
