Internal Error "Image to contain NaN (not a number) Value - Latest Build
Hello everyone,
I’m reporting this bug that has happened in a couple of render already, right after the initial pass it pop the error window, it happens when in IR or final render.
Not much to say, just hit render and it happens.
I’m on MacOS Catalina 10.15.7 - Cinema 4D R23 latest
Corona Renderer 7 for Cinema 4D (Daily Build 2021-03-31)
Did you send in the scene as noted in the error pop up?
The link on the note won’t work, is the any other way to send it?
Private Uploader is the best way to do it :smiley: You can find that in the how to report issues in my signature (https://help.c4d.corona-renderer.com/support/solutions/articles/12000033461-how-to-report-issues-c4d ). Thanks!
File uploaded!
I had to use the dropbox way cuz of the file size.
File name: Rafaz NaN Error.zip
Thanks!
Have you tried using a previous Daily build? (the one from Feb 17th?)
Please share the outcome.
Regards.
yes, I had to go back a version and it works fine!
I just wanted to point it out. Thx!!
Today’s new build seems to have fixed my constant NaaN-ing! Thank you
Thanks for the update on the topic :smiley:
