Today we are proud to introduce RoomBox, our new SketchUp extension! ?
It supports Enscape out-of-the-box, so I though the community here might be interested. Don’t hesitate to remove this thread if it’s off-topic.
Render-ready interiors in one click
Instill life into your SketchUp models by quickly and easily populating facades with render-ready rooms.
Render-ready interiors for all your needs
The largest collection of rooms ready to be inserted into your models. Shops, office spaces, living rooms, bedrooms, kitchens… You name it!
Every room comes with both night and day versions as well as low and high resolution variants.
Instantly create and edit rooms
Adding a room to your models is a breeze: select it in the library, click on a surface in your model, and you’re done.
Once a room has been created, use our Room editor to modify its contents. There’s no need to manually fiddle with interior maps in an external image editor to get what you want.
It supports Enscape and V-Ray out-of-the-box.
Keep your model lightweight
A room is made of just a handful of faces, but from a distance it looks like a fully furnished, textured, and lit interior.
This keeps your model lightweight even with dozens or hundreds of rooms.
Import custom rooms with RoomBox Pro
For unlimited possibilities, you can even create custom rooms by importing your own interior maps.
Try the free samples
Get started right now by downloading RoomBox and trying the free rooms.
