Invalid vismat?
Howcome when I try to download materials from the download section, and then load them I get an error ‘invalid asgvis material blah blah’ or something similar to that?
Re: Invalid vismat?
It may have been a vf SketchUp material that had a linked material associated with it. If you are using the older version of vfr3, then it could have been a newer material with an added feature in it (ie displacement, or per material environment maps). After that I’m not sure. Can you tell me what exact material it is? That might be helpful.
Re: Invalid vismat?
There is also a slight mismatch in material version between VfR4 and VfR3 SR1 (VfR3 SR1 was released later than VfR4 and had a couple extra fixes in it ). This mismatch will be resolved when we release a minor patch.
