I’m using Max 2020 for this.
I have a fairly simple scene in progress. It is a house that is a Revit model, created by others, that I imported. I have applied new vray materials. I have not added any new geometry to speak of and no forest Pack stuff or other complexity.
I have 3 vray cameras set up. All are copies of each other using the same settings. I have one vray sun/sky.
I can use the IPR in the vray frame buffer with the camera that shows the front of the house. BUT, when I try to use the IPR with either of the other 2 cameras that show the back of the house I get an instant, poof Max is gone , crash. Or once got the error message shown in the attached screen grab.
I have run the vray scene converter also to hopefully correct any problematic materials from the Revit import.
I’d like to be able to use the IPR fro all the views/cameras but can’t figure out what is causing the trouble. I can send the scene to you if needed.
Thanks for any help.
