IR problem
Hey guys!
I really love the new zooming in&out feature of the 1.6 but I have a lot of trouble with it lately. When I use 2D Panning Zoom in the viewport and then zoom to a specific area meanwhile in the render window as it’s suppose to be in a workflow ( I guess) the interactive rendering stops working after a while as long as I use the region cropping or restarting max. Even the “normal” render doesn’t gives me a picture until I drop a region on it after this problem shows up in IR. Hope this makes sense
Thanks for the answers
It could mean that you somehow end up with a region which is outside of the VFB.
The solution would be to click-and-hold over the region button and select “remove all” to make sure no regions are present.
If that’s the case, then it’s already reported on mantis: Renderer for architectural visualization - Corona | Chaos
I’ve run into black screens that only render if you draw a region, it is because there are regions floating outside of the VFB. clearing as Maru suggested fixed it for me.
