IR updates every time when maps are loading to ME
Hi
IR updates every time when any maps are loading to Material Editor.
For example if IR started and I open SME, IR starts to update picture continuously wile all visible in SME’s field maps are loading. After all visible maps are loaded, IR continues to render normally. But if I pan in SME and some new map starts to load, IR updates again and again every time something new appears in SME field.
Corona 6. Max 2014
Does this happen in all scenes or just a specific one? So far I was unable to reproduce this behaviour..
Thanks,
Rowan
Finally I found the object, which somehow causes this issue - it’s Forest pack object. In this example scene FP object doesn’t have any linked objects but the fact that it is in this scene is enough to get this issue. To see it, please, start IR, get any material to ME/SME and every time when this material updates, IR updates picture too
IR-material_update.max (340 KB)
Thanks for the scene, I can reproduce this behaviour but only in your scene, I was unable to reproduce it in a fresh scene.
I will report it to the dev team and see what can be done.
Cheers,
Rowan
(Internal ID=561325477)
Thank you
For me this issue takes place in any new scene, if that FP object merged there.
Hi!
Fixed in the v10 dailies https://forum.corona-renderer.com/ Chaos Corona 10 for 3ds Max - Daily Builds Changelog #msg207389
woohoo!
