IRR Loading problem
Can I get some help please, I am really stuck with this one.
I rendered IRR to separate files, one for each frame (Animation: Prepass). Once render were finished I select (Animation: Rendering) and then this error pops out.
error: could not Load irradiance map
error: the irradiance map cannot be used in animation mode
For example my IRR files named like that: idle_gi_pass_v2-001.vrmap till 102
I tried to rename it, was thinking thats do to long names but no luck.
Any help please?
Can you reproduce the issue with a simple scene?
Also could you send us (support@chaosgroup.com) the scene and a few per-calculated frames so we could test it in our environment?
Moreover try rendering the animation form the 10th frame on and let us knwo if you still get that error.
Hi, try v2.001.vrmap instead of v2-001.vrmap.
