Is it possible to load and integrate multiple Revit files on Enscape
やあ。
Enscapeに複数のRevitファイルをインポートして統合することは可能ですか?
また、Revitで複数のファイルを統合できるかどうかも知りたいです。
はい - 複数の Revit ファイルをインポートして Enscape に統合することができます。Enscape アセットを含む Revit ファイルを別の Revit ファイルにリンクすると、すべての Enscape アセットがレンダリングされます。Enscape は、リンクされた Revit ファイルのシーン全体をレンダリングします。
Yes - it is possible to import and integrate multiple Revit files into Enscape. If you link Revit files containing Enscape assets into another Revit file, all of the Enscape assets will render. Enscape will render the entire scene of linked Revit files.
Yep, works a treat, and as Phil said you do need to set the links up in Revit.
For example we produce separate Revit models for Proposed Site, Proposed Buildings etc.
Link the proposed buildings into the proposed site model and run Enscape. Any Enscape assets within the proposed building models will also render in the site model.
So far we have not found any limits on how many Revit links Enscape can handle (some of our projects have multiple proposed buildings linked into a single site model).
However we have noticed that the more Revit links you have the slower the load time for Enscape, but this is to be expected due to the total amount geometry Enscape has to handle.
Overall this works very well for us, and is integral to our workflow - 1 person can be modelling the buildings and another can be modelling the site.
