Is there a way to use Corona without the inclusion of the Denoise technique?
Just choose “None” for denoising, and render for more passes/longer time/to a lower noise limit. Why would you want to not use Denoising though?
I don’t know if I understand you correctly but you can turn off denoising. When it’s turned on you can still hit cancel button instead of “stop” button so corona will not denoise your frame. But as Tom mentioned why would you want that?
