I’ve got some motion data saved out as a max script and when I run the script a regular Max camera is created. Is there a way to get max to create a Vray camera instead?
Have you tried the amazing Lele tools (easy to get from scriptspot) wich can convert any max camera to a vray cam? I believe those scripts are donationware. Hope that helps you out devin. Works out great for heli cam motion tracked shots.
Thanks so much that sounds like it’s exactly what I need.
