itoo Forest pack material conversion problem
Hi Guys !! when i convert forest pack materials to corona materials , all texture with alpha map aree converted in a wrong way , alpha map is not applied . same problem for laubwerk trees :frowning:
here is a rendered tree and an empty file containing the leaf material ( laubwerk tree )
any advices please will be greatefully appreciated
material.zip (6.07 MB)
To clarify it a bit more, the opacity texture in some of the leaf materials is a tif and the bitmap_texture map is set up to use the alpha of this tif as a source. It actually doesn’t matter if converted or not, standard materials or corona materials do not recognize these settings.
Duplicate: TIFF/TGA/PNG/ETC textures with alpha channels not working properly - Corona for 3ds Max :: Issues - Chaos Forum
Thanks Guys !! helpful
