Jagged lines or edges
Hi, how are you?
I hope that very good!!
I am writing to see if you can help me.
In several scenes when the lines are tilted in both textures
as in edges, a jagged result comes out.
How can i fix this?
Thank you
See this post… may be helpful.
https://forum.corona-renderer.com/ What are these jagged edges? Anti aliasing problem? #msg93241
I’d suggest rendering at a higher resolution and scaling it down if need be. Or you could try using Bloom and glare, highlight clamping or increase the filmic highlights.
increase AA to 20 pixels or so. should fix all jagged lines.
thank you very much for answering, I see how to fix and I tell them
