kerala vernacular architecture…(building typology-“naalukettu"or"chathushala”)…
…central courtyard..
..60sss…
Re: kerala traditional house courtyard
the ceiling woodwork looks awesome!
would like to see another view if possible. The moss in the water is really cool. Good idea.!
-Gallystops-
..thanku..gallystops ..
definitely i will post more views..give me a little time friend…
very poetic update jeje
nice work bro, but maybe you can improve some little details to make your image even better. bump and reflection on the wood walls is too much in my opinion, texture in the perimeter of the pool is very repetitive and flat, the white material of the steps on the water needs more work maybe a little dirt on it cause its on water and that cause some effect on real life, on first image the POV is very forced, hope this helps bro.
the perspectives are not my favorite in this render the angles are too far and need to be adjusted…
tanku arqestevez1
to teofas:thanks bro.i will try to change them all…but what u mean by POV ..can u pls explain.?
to kepler:i changed the field of view friend..i will correct it for the next scene.tanku for ur advice…
