Keyframe Tone Mapping settings in camera tag
Hey there!
A colleague of mine just tried to animate the exposure value in the corona camera tag. Turns out, that the only parameter you can keyframe are the enable and override. Even though there’s the little keyframe-diamond in front of all settings.
I tested it on my machine => outcome is the same.
We both use cinema 2024.4.1 and corona 11 (hotfix 1). He’s on a mac pro m1 and I am on a PC with windows 10.
Would be cool if you could take a look (maybe this is fixed in newer versions?)
In a new scene just drop a corona camera and try to keyframe said settings.
Thank you!
Greetings,
Moritz
Hello @HFPatzi,
Thank you for bringing this to our attention.
This is expected, I’m sorry for any inconvenience.
Still, you can log this as a feature request on our Ideas Portal: https://support.chaos.com/hc/en-us/articles/27701668531729-How-to-request-a-new-feature
You will need to pick “Add a new idea” and describe your feature request in detail.
I hope this helps.
Looking forward to hearing from you.
Hey bnji!
Thanks for your answer…and sorry for the delay :wink:
Maybe then it will be best to remove the little Keyframe diamonds on this parameters, to avoid confusion, won’t it?
(If this is the case with newer version of corona, ignore my suggestion :wink: )
Have a great day!
Moritz
