This is my first personal project in Corona for C4D. Well known Peter Zumthor’s atelier in Switzerland.
There is some noise on the leather material on chairs and bench, I guess I’d have to wait a bit longer (or maybe the bump is to high?) Still need to figure that out.
Trees were made in Onyx.
Done in corona A3, a4 is too buggy atm.
Comments & critiques welcomed!
The image looks compressed a lot. Could you upload raw file?
Here are some suggestions about the noise in reflections:
-DoF is clearly visible, so you should decrease GIvsAA value to 4-8 to get optimal results (more AA is required)
-not sure about C4D version, but in 3ds Max sun object has an option to disable sun visibility in reflections - that would definitely help in this case, but would make the image less realistic
-you can try lowering reflectivity of that leather/wood material and maybe decreasing glossiness (making reflections more blurry)
-what is your internal resolution value in render settings? I would suggest using 2, but it may eat a lot of RAM in this resolution (it should help with fireflies, though)
Personally I really like! I like the angle, the details and the overalls.
By looking at the chairs I’d say the bump might be a little too high (if it is the bumps fault). The compression though is rather poor (to the point of emphasizing DOF) although that in itself is kind of refreshing to see in a way as most renders these days are super sharp.
