Lame shades, Paper, and See Through fabric Materials
Im requesting preset material settings like the “grass” and “ceramic” for Paper and see thru curtains so that they render properly when light shines thru them.
Hey @RDG_PLANNING_DESIGN , the trick with curtains/fabrics is to use very fine cutout maps and NOT use the transparency setting. I’ve attached a sample file you could use for this procedure to try it out for yourself. Make sure to also set your corresponding materials to planting since that will allow a bit of light intake of the object itself then where it’s needed. (called subsurface scattering)
If that doesn’t help and you would still like to see further keywords like these, let me know.
Thank you for your help. Yes this does help. But it adds a few extra steps. I think it would be much easier if there was a keyword or Material Type. thanks!!!
Okay then! I’ll gladly file your feature request of course. :slight_smile:
