large residential project,simple modelling and rendering
thanks to the function of proxies I can finish this model in just half a day. The residential buildings and trees are all proxies. They are blocks in CAD drawings and components when input into sketchup. I just need to replace the content of each component by proxy. Very convenient!
some little regrets:
  1. the color and reflection of the glasses are still not perfect and I want to know if there is a method to create the effect of glasses close to renderings.
2, if I use two point perspective in Sketchup and then move the rendering area, it won’t synchronize in enscape window.
  1. the grass effect looks strange in distance.
After all, thank you very much for such a useful software. The quality is far better than sketchup output while the efficiency is highly raised!
Looking great :slight_smile: Regarding the windows: Make sure to make use of the keyword based materials:
https://enscape3d.com/knowledgebase/sketchup/
The keyword glass or glazing and a opacity value of 0 should make the windows look much more realistic :wink:
