Rendering with the latest nightly (March 31) I rendered 13 hours and my noise level was around 10% if I recall correctly.
Rendering the same scene with the previous nightly (Feb 17th Daily) , after 54 min it is on 10% noise already.
We’d need more info please - either at least 1 frame of the scene so we can see what you are rendering, some info on the scene set up in case it has something unusual in it, and of course best of all would be the scene itself, sent via private uploader.
TY for uploading! Although it won’t be me looking into it, just wanted to write and say we definitely keep all things confidential and inside the company only (scene, any images and tests, etc. - won’t be shared anywhere).
One thing though, can you tell us the filename of the upload here so that we know to associate that file with this report? Thanks!
I just wanted to confirm Tom’s message that if we almost never (only with consent) repurpose user reported scenes in a way that would compromise them. I also use encrypted disk for testing.
I’ll look into the scene, thanks for sharing it,
Jan
I can confirm that build from CRN_31.3. is almost 8 times slower than build from CRN_17.2.
Also I’ve noticed that build CRN_31.3. uses only half of cores I got.
Thanks everyone for your reports, we will look into this with high priority. (Internal ID=672805567)
For those who have reported that CPU is not using all cores (in my case, as of current testing, I am using all cores), can I have your CPU specs? Also which version of C4D are you using?
I dont have the latest build installed anymore and I never checked the core usage.
I do have a AMD Ryzen 9 3950X (16 Core), not sure if that help at all
