Does anyone know how I can look up to see what the latest RCM installed is? I don’t know if this is a bug or not, but my viewport “rendered” view doens’t always match what VFR renders. For example, I’ll create a wood material, then apply mapping in the RCM, get it looking just right in the viewport then render -- and the render won’t always come out looking like the viewport. I’ve got the texture on the same channel as the mapping, btw. Maybe this is an out of date RCM. I’ve installed the latest Vray beta, RC1. Thanks,
All of the mapping functionalities are handled as a core Rhino function, not through RDK (this is with v4). I say to upgrade to the latest rhino SR (they just released sr3 yesterday, but with sr2 you should be good). I don’t think that will necessarily solve the issue, but its good to have that possibility checked off.
Thanks Damien. I’m on SR2a now, I’ll try SR3 and see if that works. It doesn’t always behave in this manner so I’m not really sure what’s going on. I’ll let you know if this works in case anyone else runs into this.
