LC with camera path option + lights animated
can it be that the camera path option for LC will not work well with animated lights? One light that is turned off (intensity = 0) untill frame 100, beginngs to shine couple of frames earlier.
Or do we make some stupid things in the last night…
Rendering with BF (primary) and LC.
Lars
Are you using a single-frame light cache for that?
yes. is that wrong?
what is strange is that when the render starts to render e.g. frame 100, the LC seems to build at frame 1 - at least that is the frame you see during the LC is build…
This is correct actually, should be working fine. I will test this here is a moment.
Just render another test and it works now as expected. Lack of sleep, I hope.
