Leisure Centre
This is a still we’re producing from a leisure centre movie. We have to produce an exterior, pool, gym, reception and bar.
I posted a thread on how to produce bubbles in the spa a while ago in anticipation of this. It’s been on a backburner since then but things are back on track. I’ll post the solution to the bubbles problem in the correct thread when I’ve finished the movie.
If anyone has any recommendations for improvements to the pool they would be greatly appreciated.
Cheers
Saul
[/img]
Here’s the external…
throw a noise map into the bump slot for the pool
noise size about 10 or so and bumpmap intensity of about 5 should do nicely
nice saulman, i agree on the slight bump.
Also you might want a touch more contrast in the image. look a little flat
Thanks for the comments, chaps. Much appreciated.
I already tried bump/noise with a few settings on the water but each time it just made it look less realistic to me. I’ll give those suggested settings a go and see what happens.
The contrast/brightness will be sorted out in a video/photo editor later.
Cheers.
Try throwing some light pool caustics on it! and yes a noise bump at a low setting will yield a nice looking water.
