Lens effect on large renders
The lens effect size seem to be in absolute numbers if I´m not mistaken.
I´m rendering images in the 7000 pixel range. The lens effect size is at maximum, but at renders this large the lens effect seems too small to be visible.
Is there a way around this?
Hello @kimmo_hernborg ,
The image resolution shouldn’t affect the size of the lens effects. Could you try increasing the Intensity and the Threshold to see if the lens effect will appear? It would be helpful if you can send us some screenshots to demonstrate the issue. Thanks.
