(in the latest Vray v3 for Max 2014)
Hi
If I want Bloom I go into my Environment and Effects panel, choose Vray Lens Effects, turn on Bloom and set accordingly.
Ace, I get a bloom.
After my render I click the new end button in the VFB (open Len Effects Settings) and modify/tweak my Bloom. BUT those settings are now different to the settings in the Environment & Effects panel. When I send to my network renderer (Royal Render in my case) which of my settings are correct?
From a quick test on a local render it appears I have to have it ON in Environment to recognize it in the VFB settings but a colleague found on a network render it didn’t matter if it was on in the Environment panel.
So
- which combination of check boxes turns it on?
- which of the settings is correct when both check boxes are on
- does it need to be on in the Environment dialog box to work?
- all the above on a network render?
Insanely confused. Having the settings in the VFB is great but lets make it consistent eh Vlado?!
Cheers
Marcus
