Background:
I got a project in layout phase, try to create an image using different camera angles, different object positions etc. When I find something good I quickly hit render and save it in the VFB. I do this a couple of times until I have n images.
Current workflow:
I re-load every image in the VFB history that I find pleasing, one after the other, into the VFB, then save it out as JPG to send it to the customer.
Optimized workflow:
I mark all the images in the VFB history that I wanna send out, right click them, select “save as” and the files all get saved (RGB Color pass that is. If you want to cater the nerds too let me select which pass I wanna save) with a number like 001 - n and/or with a suffix containing the string I wrote in the comment of the appropriate image in the VFB history.
