I have problems with licenses beeing in use after the update. I get an 1002 error when someone else is rendering.
We have to 2 dongles where each holds 10 licenses and another 3 where each holds just one.
All dongles are attached to workstations. The rendernodes have those two workstations with the 10 license dongles
set as license server. When someone else is rendering all licenses are in use and I can´t even render local wihtout DR because
the 11. workstation license is in use to. In vray 2 we had the a similar setup, where 2 workstations would act as license server
for the rendernodes. When all were in use, one could still render local without DR.
The status page looks like this.
V-Ray for 3ds Max 3.0 Total Engaged Free
Interface licenses 1 0 1
V-Ray Render Node 3.0 Total Engaged Free
Render licenses 11 11 0
The problem seems to be it uses 11 licenses from the dongle instead of 10 wich also includes the
license to render local on the workstation. Is there any solution to this problem ?
