license server problems
This happens usually because a firewall terminates the connection as soon as it is made. It’s hard to say which software/hardware is the problem though - it may be something outside of your control. If you still cannot get it to work, let us know and we can get you a local license for the home machine.
If you can change your IP address’ netmask to 255.0.0.0 instead of the default 255.255.255.0, then t should work.
When you’re VPN in, can you ping the machine the VRLserver is on? If you can’t even ping it, than you have something bigger going on (like the netmask thing).
I seem to be having the same problem.
Just upgraded to Max 7 with sp1 (from 6) running on a new machine with xp sp2 (I know. Not my choice) and have the “All of the VRay licenses are engaged” message.
Latest Vray installed too.
The machine running VRLServer is 2KSp4 and has allowed rendering over the network in the past.
Xp firewall is off, and the service is disabled too.
IP address’ netmask changed to 255.0.0.0 and pings okay.
There is a firewall running on the 2k machine though it has been tried with it turned off and still no go.
Update - Thanks for the e-mail Tisho. Tried re-installing VRay on both machines, disabling the firewall and all components (removing it too). Nothing. No other instances of VRay are running. Still the same prompt.
Too little sleep probably means I’m not at my clearest but am open to suggestions.
Where is the sleepless Zombie smiley when you need it :wink:
yep, I can ping the machine that the server is running on when I VPN in, but using VNC, I am unable to ping my machine here from the server machine. Maybee this is the problem?
Im sure its some kind of firewall thing. but i’ll ask the IT guys this week if they have any ideas
Thanks Vlado, I’ll keep mucking around with trying to get this to work without needing another key for now
