Hello guys
This is wip which i’m working on (max 7 + vray 1.46.15)
first image i used
first bounce : irr map , hsph = 50 , iterp = 20 , preset medium.
second bounce : light cache , 1500 subd.
the pic rendered with no pre calc sollution.
render time was around 2.5 hrs
second image
first bounce : irr map , hsph=25,iterp = 20 , preset medium.
second bounce : quasi on default settings.
for this pic i pre calulate sollution on half of the size and then renderd using the saved irr map.
render time include sollution was 40 min.
so from my tests i think irr map + quasi is faster and smoother.
what do you think?
How can i reduce the noise on the right wall?
Whats your min/max rates and material samples?
if you mean on the reflect interpulation that it is -3 , 0 but i never touch those…
You have glossies on the walls?
That is not for the noise problem but,
was your ‘check sample visibility’ option on?
i have glossy on the walls and it is 3 subdv
no it wasn’t on, what does it suppose to do?
what subs do you have on the vray lights around the tops of those walls?
I have 8 subdv on them
Mmmm thats pretty low. Try cranking them up to 20 and see how it looks.
**Note: Just do a render region around the area of the noisy walls, no need to render the rest of the scene just to test out that small area.
Ok i’ll try that, what wolud you choose? irr + light cache or + quasi?
Are you looking for speed or quality??
For speed i would probabaly go LC/QMC, for quality i would go QMC/LC.
For inbetween (i.e. good speed/good quality) probably IR/LC.
when i use ir/lc i’ve used 1500 subdv on lc and its still isn’t enough
how many should i go?
btw , from what i’ve seen in those pics is that ir/quasi is faster and better quality.
how can i make them better?
Mmmmm 1500 is alot for LC, you should have a fairly clean scene.
What other settings are you using for LC?
I would suggest you quickly try the following and see if it makes much of a difference.
subdivs = 1000
sample size (leave at default) = 0.02
scale = screen
store direct light = unticked
show calc phase = ticked
Pre filter = ticked @ 50
Filter = Fixed
Filter size (detault) = 0.04
This is obviously simple settings and could definitly be find tuned, but i just want to see how your render looks with these settings and your vray lights @ 20 subdivs.
thanks DaForce
will try that
what about ir settings?
mine is hph = 50
interp = 40
and medium prest on (-3,-1).
one more question , should i do a pre calculate soluttion on half of the size and save ir map or just render it on the final size?
np ![]()
Well those IR settings should be ok. See how you go after changing the other stuff.
Ideally render it at the final size to get best quality but at an extended time.
I reckon just try LC/QMC for a test and see how it turns out. Use the LC settings i posted above but lower the LC subs to 500-600, and just leave the QMC settings at default. This should give a pretty fast render, with reasonable quality.
I think the main reason for for the difference in rendering speed is that in the first image you used hsph=50 and in the second image hsph=25 for the first bounce..
Regards H.Kroeber
Ahh yeah i didnt even look for that.
But i dont think that would account for a 2 hour time difference.
gilicom:
Also make sure you have store with IR map unticked for the lights.
Well you could try ticking it put you will need a lot more subs, and wont work if you have only LC and QMC for rendering.
<edit> double negative ![]()
2 questions
If i would like to pre calculate on half size i would have to tick that right?
when using a saved ir map that was calculted using ir/lc , when i render it from file i have to choose for sec bounce - none right?
Also make sure you dont have store with IR map unticked for the lights.
wouldn’t it make my render time go way too long??
2 questions
Yes, you would tick that.
Yes i believe that is also correct.
Longer… yes, more accurate.. yes. Depends on what your after.
I would leave it unticked and then turn the subs abit lower. But if you turn it on you need to turn the subs up to get a cleaner/accurate shadow.
It would be that much longer…but definitly longer
