Light Management Browser
Status: released
I am a lighting designer and this would be great no see.
I would also in addition would like to be able to set lighting scenes then in presentations I can show clients different scenarios.
Submitted on AHA Ideas by jwal485 (ENSCAPE-I-796).
it just makes sense :slight_smile: this does not need any further elaboration :slight_smile:
Submitted on AHA Ideas by franz außerstorfer.
Need to add lights for archicad as current set up is very limited and archicad lights can be very cumbersome
Submitted on AHA Ideas by john.
This is very important especially when fine tuning lighting setups or trying alternative setups.
Submitted on AHA Ideas by jtubb.
Being able to change all lights from a central location would be useful. What I would also like is to be able to set the brightness of each bulb with Lumens, since this is the unit provided by most manufacturers.
Submitted on AHA Ideas by seven_plus_7.
Would increase the easy of work
Submitted on AHA Ideas.
I want to have it
Submitted on AHA Ideas by choacchoac.
This would greatly assist with the rendering of intrior spaces correctly lit.
as a lighting designer i would prefer this, also add some more options to light prefs, like changing light from warm to cold white with correct Kelvin Numbers.
To save a huge amount of time without being obliged to select one by one the lights on the sketchup project.
Submitted on AHA Ideas by tchan.tings.
Being Able to adjust Light without having to do this very painfully in Revit would be a huge improvement
Submitted on AHA Ideas by mruehr.
I work as a lighting designer and this would allow me to show differing senarios to clients on the fly, currently its a very time consumint process.
Submitted on AHA Ideas by jwal485.
One of my biggest complaints about enscape is trouble with light balancing. Frequently the lighting in a scene is calibrated incorrectly in Revit, or was cranked up by someone else working in the model to get their rendering to look right, which can throw things out of balance. Temporary light adjustment would be a life-saver in balancing renderings and would really help cut down on pre- and post-processing time!
Submitted on AHA Ideas by ntorstenson.
with keyframes for video
Submitted on AHA Ideas by d.pires.
This would make it much easier when having many lights and to try out different lighting conditions.
Submitted on AHA Ideas by peter.
the current method of adjusting lights is complex, time intensive and painful. a tab that coordinates all settings (as well as identifies which are linked components) would be a boon to project workflow
Submitted on AHA Ideas by corey.
Critical! Workflow would greatly improve. Its to much hassle to handle large amounts of lights right now
Submitted on AHA Ideas by thijslankers.
THIS WILL BE A GREAT FEATURE/ADDITION. iRENDER? WAS ANOTHER APP WE USED TO USE. YOU WERE ABLE TO PLACE “LIGHTBULBS” (POINT LIGHT SOURCE ONLY) NO OBJECT WOULD APPEAR, JUST THE EFFECT.
I JUST STARTED TO PLAY WITH SOME OF THE LIGHT FIXTURES/EFFECTS TODAY. THEY SEEM RATHER WEAK IN THE LIGHT ‘DISTRIBUTION’ OR EFFECTS. OR THE LIGHT IS JUST VERY DIFFUSE AND HAS A WIDER PATTERN THAN ACTUALLY WOULD HAVE? I KNOW THIS IS A VERY DIFFICULT TASK AND I APPRECIATE ANYTHNG IN THE LIBRARY WHICH CAN BE USED IN OUR RENDERINGS. WE ARE LANDSCAPE ARCHITECTS (AND ARCHITECTS IN OFFICE TOO) BUT I AM WORKING WITH OUTDOOR SPACES AT THE MOMENT
Submitted on AHA Ideas by dhimberger.
To help control lighting without selecting the light
Submitted on AHA Ideas by riendeau.
for obv reasons :wink:
