Light Material and Light Object -> Shadowcatcher Problem
Hello, we have the problem that the mirroring with the Shadowcatcher does not work for different light types. Is this error known?
See screenshot for more Details..
Full-speed non-debug version
Build timestamp: Oct 15 2019 19:04:23
Version: 5.0 daily Oct 15 2019 (core 5 (DailyBuild Oct 15 2019))
Cinema version: R21.026 Cinema 4D (mutli-license)
Plugin status: Plugin successfully loaded
Is “Shadowcatcher Illuminator” enabled for the lights and light materials?
Hello Tom, you´re right, shadow catcher illuminator wasnt enabled at the second object, but doesnt work with light material width opacity and the light object (there isnt any checkbox..) in the scene.
Scene and Screenshots attached…
*Edit
improvemen: is´nt it possible to turn on the shadowcatcher illumination checkbox by default?
light-scene.c4d (511 KB)
Hello again, is this a mistake or have I not considered something?
Hi, the shadowcatcher option should be added to the Corona light object. We will fix this…
As for the light material with opacity, it works for me - see attached picture
Hi houska,
i´ve found the problem, its because of material stacking.
See attached scene and screenshots.
stackthing.c4d (433 KB)
Hi tuami!
Thanks for the clarification! You are right, I didn’t try to combine it with material stacking… This is defnitely something that needs to be solved. Thanks again for the report!
(Internal ID=418950187)
