Hi, i need a help about light portals. Both Images are made with 30 pass(Interations) PT+HD Cache
My question about the more noise with light portal
Can you strip down the scene and upload it for me ( http://corona-renderer.com/upload )?
Edit: Fixed the link so it works (Rawalanche)
HDRI can produce noise with portals!
Solid glass in windows? Overlapping faces?
inactive topic.
The reason is probably that the map has high dynamic range, portals can be bad in that case. You can get better result by decreasing portal fraction in devel/debug rollout
