This is what happens when I change spherical light’s radius to some higher values. Number in file name is light and sphere radius in cm. Light and sphere radius in max has the same value. Changing it to higher values makes it even more insane - light becomes tiny or invisible.
On those 2 screens with viewport you can clearly see something is wrong, radius was 600cm.
