Lighter text color for dark UI
Using max dark UI some useful infos are almost unreadable for me as they are written in black over dark gray**, as an example:**
- the mini DMC calculator
- color correction in VRFB, some are obvious but others are not (ex. values in levels rollout)
- override material button
can you please make them a little brighter?
Hm, nobody has complained so far. Does anyone else feel this way?
We have very limited control over those colors anyways. You might be able to adjust many of them through the 3ds max UI customization dialog.
Well, I understand it’s not a big issue but I’ve just double checked making some guesswork.
Let’s take as an example the mini dmc calc for a vrlight:
it seems to respond only changing the color of 3D Shadow item under customize UI-color-custom color; that’s fine but it also has a big impact elsewhere around the UI; here the suspect it has been assigned to a wrong tag or whatever.
The standard color as “Subdivs” above in the same rollout should be fine …it’s a pity to make it appear as disabled …it’s an useful info
