Hi all,
as from subject, sometimes the Lightmix setting is not reloaded reopening the .max file.
There is a way to solve it?
Corona 5.
thanks
Hi all,
Corona 5.
thanks
Do you mean that LightMix colors are reset to white and intensities are reset to 1 if you open a file which was saved with different LightMix values?
I don’t know regarding the colors, but yes the intensity are reset to 1 when i open a file which was saved with different LightMix values.
I suppose that happen when i insert manually a lightmix element.
Hi LorenzoS, we were able to recreate this, issue has been reported.
Thanks for the input.
(internal id=436261825)
Hi Georgek,
do you have any updates?
Up
No specific updates yet, but we will be sure to share them as soon as any decisions are made.
having same problem but only the last lightmix element in the list resets (to 1 and white) each time i open the .max file.
Fixed in v6 RC1
V6 rc1 3dsmax 22020.
-open files,
-change one or more value in ligthMix and close the files,
closing the files max dont ask to save the changes so when i reopen the files, the last setting in ligthMix is lost.
I have just tried this and 3ds Max asks me to save the file when I try to close or reset 3ds max.
Can you provide some video showing me the issue?
Rowan
Today i am not on office,
ASAP i will double check and will send something to more clarify the issue
Rowan, can you try to choose “new files” instead of close directly the max file?
in attachment the video showing the issue.
Thanks for the video, it looks like it only happens when rendering with IR.
If you render with the production renderer then you will get the prompt to save the file.
I have just tested and it behaves the same in v5, however I’ll see if there is something we can do about this.
In the mean time a workaround would be to just save the file before you reset it (File->Save). In this case the lightmix values are stored and correct the next time I load the scene.
Cheers,
Rowan
(Internal ID=544069227)
