Like"FStorm GeoPattern" corona pattern
Unfortunately not. I’ve had a few jobs where I had to switch to FStorm from Corona purely for Geopattern usage. There are some limitations though - your base object UV mapping needs to be perfect, as does the “crop” box on the tile-able sampled pattern mesh to avoid visible open edges.
Thanks for the answer, i guess i have to look at railclone now.
If your UVWs have stretched areas, the mesh with stretch like that too ?
BTW, no one answered me this yet but since you already tried Geopattern, didn’t you try to install VrayPattern and render Corona scene in VrayNext ? Since VrayNext supports lot of Corona features, and also VrayPattern, wouldn’t it work like this also ? I.e render scene with Corona materials&light in VrayNext, but apply VrayPattern on (I’ve no idea how you apply it, is it modifier or map…?).
Yep, the pattern will stretch/conform to the base object UV’s.
If I remember you were the one to suggest me RC years ago when I asked for the pattern! :smiley: yzyzyzyz
Can you give more information on the task? There are ways to do “almost patterns”
I did for Alphas, Corona 1,2 and 3 never worked
It’s only since 4&5 that VrayNext supports CoronaMtl (and not sure which lights) and Corona VrayMtl. So it should theoretically work if you keep whole scene in Corona, maybe except the materials with GeoPattern (convert to VrayMTL), keep lights in CoronaLight, if doesn’t work, convert those to Vray, results should always nearly match.
I need to test this but I don’t have VrayNext…just 3.6.
guys plz, i need CoronaPattern so much) it will be gamechanging feature for me! hoping to get it in V6
Nice FStorm GeoPattern video, I would like to see it in Corona.. very powerful
I am sure we’ll get it eventually :- ). Dem fabrics need it!
Corona Pattern is preliminarily planned for V8 - Trello
Implemented in Corona V9: https://forum.corona-renderer.com/ CoronaPattern playground!
