Vray beta seems to install fine (also run a repair), but when I run SU I get a warning dialogue:
‘Activation Manager Init failed(126) - The specified module could not be found.’
I then get the following load error:
‘Error loading File VrayFOrSketchup.rb
1114:A dynamic link library(DLL) inialization routine failed.
C:\Program file\@Last Software\SketchUp5\Plugins/VrayForSketchUp.so’
I’m running a PC dual core Intel Xeon 3.2GHz 3.19Ghz with 2GB of RAM and a network version of SketchUp 5.
Thanks for your help…looking forward to seeing what it can do.
Typically this is the error you get if you do not have admin rights to install software. The VfSU installer needs admin rights to install. If you have admin rights please let us know. Otherwise try installing with admin rights and lets see what happens.
thanks for your help, I had logged on as an adminstrator to install, but did not realize that you need to be logged on as an administrator to run the program also.
